Re: Mostly Kendall gt-1 10w30 soup, 1500 mi Subaru winter oil mix.
MOO/Oil: 1500mi. / approx 3qt 10w-30 Kendall dino + 1 qt M1ss 15w50 + additives
Dates: OC/Sample 30.9.2003 / 1.2.2004
Engine/MOE: subaru 1.8l, ej18 / 114,000 mi
Lab / Data: mtm industrial
Al 1
Chr 0
Cu 4
Fe 0
Pb 2
Tin 0
Si 5
K 0
Na 12
Mo 205
Water 0.2
Properties of the soup:
Oxid less than 2
Vis@100 11.8
Nitration 2.7
Glyc not detected
Fuel 3.6
--those are all the numbers--
I couldn't handle the low rate of UOA's here so I finally sent in my first sample ever last week; the oil only has 1500 miles on and is four months old. This is my first UOA and this now officially makes me a BITOG oil addict.
Since this is a new car to me (Impreza bought at ~110K) I was mainly worried about some disaster like coolant in oil. I was also worried about high wear due to other causes such as short trips and winter conditions, but this worry luckily turned out to be those from a hypochondriac-like oilhead, except for the fuel detected, 3.6%. I was very happy that no wear was detected at all, although realistically this is probably due to uncertainties in instrumentation; but very low wear apparently. Na might be high from additives I dumped in the mix. No glycol detected and just a trace of Silicon.
Re additives and the Kendall soup:
Contains an effective net estimated 1/2 to 3/4 bottle of molyslip added after oil change, and ~1/2 bottle of kmart STP clone shortly before sampling at 1500 mi which I hoped would add zinc to the soup. The reason for the uncertainty in amount of molyslip (mr. moly) is that I drained approx 1 qt of the Kendall dino (after adding mr. moly) 100 to 300 mi into the OCI in order to thicken the viscosity with 1 qt of M1 15w50 and in order to do a visual inspection of the oil. (Yeah, it's complicated and these are all possible symptoms of an oil hypochondriac.) Considering one would expect 800-900 ppm moly from a full dose of mr. moly & about 4 to 5 ppm FE according to a prev post (do a search on molyslip in the VOA board), I think these are some possibilities or contributing factors:
a.) stuff settled at bottom, drained when draining 1 to 1.5 qts of 10w30 which i replaced with 15w50, hence may have gotten rid of most of the molyslip.
b.) lab instrumentation saturation or error in sampling the moly
c.) molyslip reformulated their product; the previous product did seem to be overkill regarding the moly levels--if so this is unfortunate, I was hoping that can i have left over would last me for 4 OCI's judging from the VOA on molyslip.
I plan to sample this again at a higher mileage, 3000 to 4000 mi so that one can make better sense of the wear numbers (which I assume are +- one two, or three ppms perhaps.) Once I get a background idea on wear patterns with another 2 UOAs, I can move on to a fuller spectrum UOA, like Blackstone.
Oh, another thing, when I sampled the oil in the white plastic container and did a visual inspection I was slightly worried about the tan/camoflage green tint of the oil. I suppose this is due to the moly and all the other gunk, luckily not coolant.
Also, the Mobil 1 is doing a good job keeping the viscosity up despite fuel contamination plus the cold weather is going away; current oil should be good for at least another 2K in my opinion.
[ February 09, 2004, 09:29 PM: Message edited by: giant_robo ]
Al 1
Chr 0
Cu 4
Fe 0
Pb 2
Tin 0
Si 5
K 0
Na 12
Mo 205
Water 0.2
Oxid less than 2
Vis@100 11.8
Nitration 2.7
Glyc not detected
Fuel 3.6
