Originally Posted By: aquariuscsm
Originally Posted By: ekpolk
Click here to see a nice article that pretty well sets out the basic difference between flat and roller designs.
Excellent article! That`d how I always thought a flat tappet cam looked. Seems way more primitive than a roller cam. Are all modern engines roller cam nowadays? Seems like a much better design wear-wise.
There is actually almost no wear on a flat tappet cam, PROVIDED that a) the cam is properly surface-hardened after being formed at the foundry and cam grinder, b) the lifters are likewise properly surface hardened, c) the cam and lifter set was properly broken in (EXTREMELY critical step), and d) there is adequate oil flow. Once the cam and lifter surface have "worn in" against each other, the cam can run half a million miles without removing but a few tens of microns of material! In fact, if more material *does* wear away, the cam will quickly fail because the surface hardening layer is quite thin.
ZDDP additives are most critical during break-in, and can be drastically reduced afterward. I don't think we really know what the lower threshhold is for different engine combinations yet. I would bet that virtually all flat-tappet overhead cam engines (like the Nissan and BMW mentioned in this thread) will be fine with SM oils. Same for low-RPM pushrod engines like Jeep 4.0 and Range Rover v8s. It gets questionable with older American v8s that are more performance oriented. Upgrades like modern "beehive" valvesprings that maintain valve control with much less seat and lifter toe pressures than old-style dual valve springs with dampers will certainly extend cam life and reduce the need for ZDDP. But the problem is that a little wear on a cam will quickly cascade to a total failure if the wear breaches the surface-hardening of the cam. So finding the limit is going to cost a few cams, and I don't want one of them to be mine. There's also the problem of knowing whether it was a bad cam, bad lifter, or oil that caused the problem. My personal experience is that cams coming out of the grinders today, while much more advanced in terms of the science behind the lift, duration, overlap, etc. and capable of much greater performance than old cams, are C-R-A-P in terms of the quality of the blank casting from which they are ground, and sometimes even the finishing steps after grinding. I don't know if its junk from offshore, tooling getting old, or just plain old cutting corners for profit, but holding a new cam by a vintage one often shows *visible* differences in the surface quality and absence of voids and irregularities in the older casting.
Rollers are much better and have taken over the market, but they do have their own problems, too. The lifters have to be very precisely aligned, any sideways "crab angle" of the roller will fail the cam. Rollers on the lifters sometimes seize or break, and when that happens its UUUUUUG-LEEE! Lifter bores can get torn right out of blocks or heads. At least when a flat tappet cam fails, the lobe usually just wears away, the lifter goes cup-shaped, and the valve quits opening, and the filter traps all the fine particles that wear off- nothing sudden or violently destructive like happens with rollers.
