LouDawg
Am I required to use the Snap-On wrench, or is it okay for me to use my Crafstman?
Actually, I ALWAYS hovered over them because I have an intrinsic distrust of those guys!quote:
Originally posted by AstroVic:
Just think:
If the filter is that hard to change, imagine how many times the Iffy Lube morons never bothered to change it.
Good job on deciding to change it yourself! It's definitely worth it, and before too long you'll wonder why you ever let the Iffy Lube monkeys touch any of your cars in the first place.
I picked out a Snap-on because I figured you were a classy guy.quote:
Thanks for the info, but mine is an M14, not an M12...I'll check for the othere size...quote:
Originally posted by GoldenRod:
Here's another drain plug for your truck:
Drain Plug - Dorman
Crush washers are good.quote:
Get dealer crush washers.. they are cheap and will work for your vehicle. You did good on oil and filter selection, you will get better at the filter with repetition.
Well, you know...thanks, you're sweet! Actually, I am classy, but not wealthy! hehehehequote:
I found that too, but no price? Where to buy, and how much?
Sorry...been away from my computer all day! It was a 14mm wrench, so maybe the 12mm refers to the major o.d of the threaded area?quote:
LouDawg,
Are you going to answer my above question or not?
I guess that would explain why the 14mm washer was so loose on the "14 mm" drain plug, eh? hehehehequote:
Yes! If it was a 14mm wrench, then that means the threaded portion is 12mm.
Also remember to only put in the amount of oil stated in your manual, do NOT go by the dipstick.quote:
Drain Plug - Dorman
My 1995 says 4.25L per oil change with filter.quote:
Originally posted by racer12306:
out of curiosity what does the manual say? every 4.3 i have ever done took between 4.5 and 4.75 qts of oil.
