To be honest with you, tpitcher, Saturns are easy to work on. However, don't let the other posters give you a false sense of security-- these cars need frequent attention and they are not the most reliable, at all.
For example, my '96 SL2 has 133k on it. My parents were the original owners and my father and I have done most of the work on it. Over the course of 133k, the following items have gone wrong:
Alternator-- 63k
Starter-- 99k
A/C Recharge-- 130k*
PCV Breather hose-- 60k
Valve Cover gasket and spark plug tube seals-- 96k*
Upper motor mount- 96k*
Transmission valve body cover gasket-- 98k*
Serpentine Belt Tensioner-- 88k
Trunk wiring-- 133k*
Radiator-- 125k
Thermostat-- 120k*
Struts and front strut mounts-- 129k*
Rear Sway Bar End Links-- 115k*
The items that are marked with a star were long overdue when they were replaced. In addition to the above list, right now I still need to replace the cruise control module (also long overdue), the rear brake calipers, the lower control arms and the front sway bar bushings.
So, these Saturns can be economical to own as long as you do ALL of the work yourself. Otherwise, they can be a nightmare. Luckily, saturnfans.com is a great resource.
Alternator-- 63k
Starter-- 99k
Radiator-- 125k
Thermostat-- 120k*
