You're saying I should be able to turn the pulley, if I read this right.
A seized compressor sure would snap a belt. BTDT..
Let's go see.
Lift up the big plastic Y piece (making sure it is fully unbolted) and concentrate on removing the large inlet hose that comes from the MAF first. Then you should be able to take the smaller hoses off of the throttle bodies and remove the Y and the small hoses as a unit. You'll also need pliers to take off the pinch clamps for the really small hoses that go to the valve covers. Then you're in position to inspect / clean the throttle bodies.
There are three parts:
1. pulley
2. Clutch
3. Compressor
The pulley floats on the compressor drive and the clutch locks it to it when the compressor needs to run. You SHOULD, with a bit of effort, be able to see if the pulley spins freely (it should, the clutch is disengaged with the engine off) and, by getting a grip on the front of the compressor drive, see if you can spin the compressor itself.
What spins? The pulley? It should. It's the centre section you are trying to spin, may take a bit of work, that's the compressor drive.It does spin.
I wonder if this is a car where if I jump a relay I could test for the "Click."
A bit of Infiniti weirdness: I see no designated AC button anywhere on the dash or console.
OK, so if you can spin the compressor drive, that bodes well. What about the idler that @mk378 mentioned?
Thank you!We know you like the car. SLOW DOWN. You are getting excited, and when you get excited, you get scattered. Are you trying to get the car on ramps to look at the belt issue? You should be able to see from the top, no ramps required.
And why are you continuously wasting gas by running it in the garage? The money you are spending on cleaners, fluids and gas could probably pay for the hood struts that you actually need.
I don’t think you were asked to spin the fan clutch. Rather the AC clutch on the compressor.Okay so. I STILL did not get that piece completely OFF and I may tighten it back..
But, all that to say...
I CAN spin the fan clutch. I can spin it easily with one hand. There appears to be a normal amount of resistance, I need to make the motion with my hand to get it to spin, but as I understand it it would not just keep spinning anyway and I do not need to make any hard effort to spin it. (It doesn't spin like a bike wheel up in the air.)
