Jeep trans filter supplier?
My Dodge OEM filter had FILTRAN or Fil-Tran stamped on it in a discrete location and the anti-corrison paper had filtran all over it.
As John mentioned, In most instances, Filtran is most likely the OE supplier for most of DCX automatic filters.
Filtran sells directly to the aftermarket and you can typically buy a OE filter for less from a transmission parts supplier. Avoid the filter/gasket kits at the auto parts places. They use the cheapest stuff your dollars can buy.
DH
The one that came out of my Jeep Liberty was likewise a Filtran. I thought that was good because a Filtran was what I had gotten to put back in.
It also has a fluid return filter that I also replaced. It's a small spin-on filter with a bare metal case, no paint. Disassembled, it had a string around the element. Purolator manufacture ?
When I put the filter on I didn't look for stampings, etc. It's the tan "sponge" looking one though. Who is Filtran and are they a reputable company?
