Gents The Daughters 2000 Jeep Wrangler is due for an oil change in the transfer case. Does anyone have a suggestion as to what would be the best lube? Best regards. John
I too used Amsoil ATF in my wife's 97 Wrangler. Other than being a pain to do due to the transfer case guard, seems to work just fine.
Changed both front & rear differentials while under the car that day, also to Amsoil gear lube.
quote: Originally posted by Market525: I too used Amsoil ATF in my wife's 97 Wrangler. Other than being a pain to do due to the transfer case guard, seems to work just fine.
Any Dex III ATF will work fine in the NP231J transfer case. It's up to you to decide whether you want a synthetic or conventional ATF. It only takes a little over 1qt to fill it up so I always use Mobil 1 Synthetic ATF. Easy to find at Autozone for $4.89 qt.
