Jeep 545RFE fluid change
Originally Posted By: chevman4life
After watching a few videos on Youtube about changing the fluid/filter on this transmission, i noticed that several of the guys did not change the spin on filter washer/gasket. I've read that it needs to be done but how do you remove it? Thanks.
It is easy to do. It just spins off like other filters. I do recall that it uses a male/male adapter to attach, though.
Make sure all seals are in good shape or you will have problems.
