Jeep 4.0 Mobil Delvac 15w-40
Metro NY
What type of OCI should I run with Delvac and a 1996 Jeep GC 4.0
I picked up 5 gallons and want to use it during the warmer months.
I searched the forums but couldn't find a definitive answer for the 4.0 and 15w-40.
and also would i notice a big difference in gas mileage?
Car is driven 20 miles city round trip daily and 100 miles highway round trip every sunday. Moderate on the pedal with RPM's never exceeding 3K. also around 140K on the engine.
thanks guys
What's it going to do, go from "lousy" to "royally lousy?"
Seriously, I doubt you'll see a big difference if any. The Cherokee's mileage is limited by the shape of the vehicle and the wastes in the AW4 tranny. What do you get, about 16? My 5-speed that my daughter drives will break 21 on the highway, but not my automatic.
Well it's a 42RE and i get about 18 MPG with Rotella 5w-40.
Originally Posted By: addyguy
7-8k easy.
I'd say 10k, but too many here would scoff at that!
sounds good. also what would be the minimum temperature to start using this oil. lately the temps have been from middle thirties to low fifties.
i dont want to risk any unnecessary start up wear with a 15wXX oil.
Personally, I'd say that once it's at least in the 40s consistently, and won't get below freezing at night, go ahead and switch. Just go easy on it for the first couple minutes after startup if it's below 60 - 70*.
Woops, I saw the GC and somehow my brain read "Cherokee." You're lucky. The 42RE is as much or more of a power-soak as the AW4, but at least it shifts better... and you have rounded corners for better aerodynamics ;-)
i wish i drove around in a jelly bean
but i'm getting 18mpg with 31's and a basket on top. can't complain
sounds good thanks!
btw my oh my how Stamford has changed these past few years. Every time I pass by on 95 i see something new being built!
thanks guys
For your climate, I'd run 5W40 Rotella T6. It'll make life easier on your starter in the winter and your oil psi will rise faster upon startup with the thinner 5W. I ran Rotella T6 in my Jeep 4.0 for many years and liked the oil. A weepy rear main seal made me make the move to M1 high mileage 10W40.
