Old timer mechanic says:
If you change your oil and filter every 3000 miles it does not matter what brand or how expensive the oil is that you use, you just won't have any lube related problems??? This seems to make sense as long as the oil is the correct viscosity and meets the API requirements of the engine. Clean oil, Clean filter, no lube problems and long engine life? Thanks for your thoughts.
