This is about my 2001 Dodge Dakota, it has 158,130 miles on it, 3.9 liter V6 and a 5 speed manual. It is just a basic 2 wheel drive truck. I do no towing or heavy hauling, never go off road, commute 40 miles round trip to work 5 days a week and take the occasional road trip to Orlando or Tampa.
Lately I have noticed the ride quality is more bumpy and more rough than it used to be. It seems some roads are better than others, some are worse than others depending on the road surface and condition. I feel the shocks and bumps in the steering wheel and seat. It's not vibrations, just a bumpy ride quality. The steering wheel also has a very slight shake side to side at 70 mph. I feel that with only one hand on the wheel, if I grab it with both hands it is pretty much gone.
I changed my oil and rotated my tires today and checked the front wheels for problems, there is no movement at all in any direction on either wheel. Both wheels are tight and solid on the hub. Inner and outer tie rod ends, all 4 ball joints, stabilizer bar bushings and end links, wheel bearing/hub assemblies are all fairly new and all good quality parts still in good condition. I greased my ball joints today too.
I saw some cracks and splits in the lower control arm bushings. I am no expert so here are some pics of what I found today. What do you guys here think? Are these bushings really bad and if so could they be the cause of the rough ride problem?
Thanks for any help with this.
