I need to drain the coolant on a 3800, but it's impossible because they put the lower radiator hose too high on the engine, so draining the petcock doesn't get more than a quart or two (the capacity is listed as 12 qt)
Thankfully, it's a RWD F-body, so the knock sensors might be easier to access than the FWD versions, Unfortunately, there is NOTHING on the knock sensors on a RWD 3800. No pictures on any forums, no videos on Youtube, nothing! So I don't know how accessible they actually are. (I know the rear knock sensor on a FWD is impossible to reach due to being hidden under the exhaust manifold). While I found a video on an Australian Holden Commodore 3.8 with the knock sensors, the engine was on a stand and not in the car. And if I actually can remove them, I have to hope they don't break.
So, the only way to drain the coolant is with a vacuum filler, but they all seem to require an air compressor, which I don't have, and I have no way to use one anyway. I don't have a garage.
Is there a way to use a vacuum filler to remove coolant without an air compressor?
