Originally Posted by Bonz
It doesn't take long to get rings seated, you come back from your first ride a running it up the RPM scale and down the RPM scale and they've pretty much done what they're going to do. For that matter if the bike is "new" from the dealer, if it has gone on any test rides you know it's already been run hard. Even with 10 miles on it. Chances are if you have ever taken a bike on a test ride you have done that. Keep in mind if it's a brand new engine, it isn't just the pistons and rings and cylinder walls that are breaking in, gears are breaking in, the valve train is breaking in and everything in between is breaking in.
But with respect to the thing we think of most that would be the piston rings mating to the cylinder walls.
The key is to keep them under load whether acceleration or deceleration. That expands them out against the cylinder walls and pulls oil up under deceleration which is greatly appreciated by the rings and cylinder walls in the initial miles. I would run a conventional oil or factory fill because the first OCI will be short. After that switch to whatever you want.
Not sure if you are going to be breaking in an engine, but that is my regimen when I've installed pistons and rings and it's trouble free.
Yeah, that's pretty much what I did. First ride was about 20 miles with lots of acceleration, then engine braking back down, and repeat. Second ride was about 30 miles of the same thing. Both rides I stopped at the halfway point and let the bike cool down. I dropped the factory fill after the first 50 miles and refilled with conventional. Stuck with the conventional at the 600 mile service. The bike is now at 1400 miles, so I'll go the remaining 600 miles, drop the conventional at that point and refill with synthetic. Thanks for all the great advice guys!
