Originally Posted By: TiredTrucker
Originally Posted By: Jetronic
The vast majority of turbos in passenger cars are NOT watercooled.
Ford's Ecoboost are. VW's 1.8T engine the turbo is water cooled. The Chevy Cruze 1.4 turbo is water cooled. And the list goes on and on. Look on most any modern gas engine turbo and you will see both oil and coolant lines going to the the turbo(s). This is for a number of reasons, mostly to keep turbo temps moderate and to reduce heat soak problems at engine shutdown.
I am almost certain the turbo in my girlfriend's Volvo (low output) is water cooled. It has an intercooler line running over the engine for one and that is only found in the turbo models. Not sure if it has any oils lines running to it or not.
I do know that her car tore Valvoline Maxlife 5w30 up pretty bad and the engine was starting to sludge up. After using M1 0w40, the issue is slowly starting to go away.
