Originally Posted By: BrocLuno
To those saying that EGT on gas motors are higher than OTR trucks, you just ain't been there... Cars loaf along at cruise most of their life. Trucks, full fuel - full boost for the whole run-up through the tranny (21 speeds...) and full boost every hill. Up the grapevine it'll be boosted for 1/2 hour easy with the first 4 ft of the 4" exhaust system cherry red (including the turbo) - that's HEAT !!
The comment about farm motors, yeah, 8 hours of plowing with full boost - same as above.
Marine engines working on a push boat - full boost for days up the mighty Miss ...
Well, you do know that the EGT gauges on these three types of applications is merely bling, right?
As I mentioned, on the farm, it would be full boost for close to eight hours solid. The only times when the boost wasn't peaked was at refueling and lunch.
When I ran the Audi at full boost for half an hour, the sump temperature did not exceed 95 C. Obviously, there would be much hotter spots in the engine, but that does say something about how efficient its oil cooling system was, that it didn't run away.
