The vehicle is a 2002 Suburban with almost 300k. Its had a,non-specific leak for years and ST HM 5w30 actually helped quite a bit. But now I cant find it. Ive tried 2 OCIs with Maxlife, but the leak came back. What oil or additive should I try.
This isnt a daily driver, so I have never taken the time to track down the leak. When it started a few years ago, I switched for ST HM and it slowed it to the point where I was losing less than 1/2,qt per 4k OCI, so I just never put it as a priority. I may have to attempt to chase it down nowwhat kinda leak are we talking about here? from the valve cover? the rear main seal? In theory higher viscosity oils can slow leaks, but seals that are cracked will just keep leaking under pressure. if its bite the bullet and buy a new gasket get out your socket drivers and a tube of rtv and some pb blaster. just don't break any bolts and you'll be fine.
