'in some cases'? Yes, perhaps. Not generally though. Very most MTFs
of the past two decades are 75W or similar and the vast majority of
transmissions still live a long life. IMHO it's better to perform frequent
oil changes (remember many manfacturers spex so-calles 'lifetime' oil
fills) instead of going thicker. I've tried both thicker and thinner as well
as retaining viscosity. I've never found going thicker to be satisfactory.
However I'm aware that thinner transmission oil can increase wear and
that's why I posted what I posted above.
Sorry, 'gotta jump-in here with a graphic, and in which I believe... (Sorry, small text).
I know and it's probably still true, however 'shifting feel' ist important
as well, since it both is an indicator for synchonizer work (and oil sync
compatibility) as well as shift quality is an important part of the driving
experience. Poor synchronizer performance isn't acceptable regardless
of gears and bearings being subjected to the lowest imaginable wear.
I also monitored overall wear by observing deposit built-up a magnetic
drain plug each time.
