Crypto I have no idea exactly how long it was with out oil but I imagine it drained fast. The hole was the larger then a 50 cent piece but smaller then a 12 oz pop bottle. Yes I made it all the way home. Had I known it was dry I would have shut it off and hitch hiked but with a date that was not an option. Just so you know briggs and straton has done tests were the engines were run 20 hours with out any oil! Prolong was not out yet. I am baseing the time frame on when it first started to run hot and make alot of noise. Seeing how I had 5W50 syntec I am guessing it drained out fast. Some times things can not always be explained they just are!!! I have heard others have similar trhings happen to rule this out as a fluke. It seems that some bearing designs can last a while with out spining even in the abscence of oil. I did use what I now belive to have been a chlorinated additive wich at the time I thought saved me. It was sold in the south and was called Petron or Petron Plus. Even if it was 45 minutes instead of an hour it amazed me at the time.
At any rate I was there and that is exactly how it happened. What truly amazes me is that I was able to put another 30,000 miles on it. After that the lifter clattered real bad and it did not have as much power as before.
[ June 30, 2003, 08:50 PM: Message edited by: JohnBrowning ]
