Originally Posted By: ZeeOSix
Originally Posted By: KCJeep
Nobody really knows for sure why but there has been some speculation about oil pumps being on the weak side possibly being the cause of the low efficiency spec, which will inevitably result in high flow, a good thing for a weak oil pump.
I am getting suspicious about the Hyundia/KIA OEM filters, especially since they have had some engine knock issues that were resolved by OEM filters. They even issued a TSB about it.
It very well could be that the oil pumps on Asian vehicles are somewhat "weak", which would be a good reason to make the filter more free flowing - all that does is ensure the pump doesn't go into pressure relief sooner than it should. If the oil pump does hit pressure relief very quickly due to flow resistance, then the flow rate going to the engine could be reduced.
But even a filter like the PureOne is pretty free flowing ... you've seen the SuperBusa thread showing bench testing date from Purolator. Only 5 PSID at 12 GPM of oil flow with hot oil. Pretty good flow IMO.
Very well could be that the Hyundia/KIA engines have pretty weak, low flowing oil pumps, and they need a sieve for a filter in order to maintain good oil flow to the engine. IMO, the oil pump would have to be pretty anemic for an oil filter to make a noticeable difference in engine noises.
I agree and I don't know that anybody really knows for sure other than the manufacturers themselves. I agree plenty of aftermarket filters do flow very well at higher efficiencies, which may be why so many are used in Hyundai/KIA's without problem despite the TSB. The filter actually pictured in the Hyundai TSB regarding the engine knock was an ecore.
I am using a Napa Gold cartridge filter in our KIA without issue, but I think the TSB is really aimed at older vehicles with spin on filters.
On a side note, my Jeep 4.0 is known for an adequate but not particularly strong oil pump. My 4.0 will "knock" if I use overly thick oil in it. I tried a fill of 15w40 Delo in it once and it knocked, too thick for it, and it took a partial drain and a quart of MMO to eliminate it. That is an oil way over spec for the engine but I do think it's oil pump related and an interesting aside to our conversation.
