Well a standard oil change is basically 5/6ths of the oil out every time, you really never get it ALL. so it shouldn't make a difference.
Then why is it when most of us change oil in a four, five, six qt etc system, it requires approx same to refill?? I've pulled pan on several engines and rarely found more than a tea cup still hiding inside... On most engine it's only true if it has a oil cooler that may not drain completely...
There is also oil sitting in the oil pump, in the galleries, and in the heads---it all adds up. Compare the amount of oil listed in the repair manual for when the engine is installed with the amount for an oil and filter change---about 5:6.
OK if you say so, but I contend there won't be more than a pint in most engines... Heads hold what, maybe 2oz each?? Valley and oil pump approx same each, oil pan, maybe 6oz, that's 12oz plus maybe 1/3oz oil in each lifter/lash adjuster for a v8, that totalss a little over 17oz.. What about galleys you say??(which would be the greatest single amount) Assuming a hot engine, that oil will flow back through the main & rod bearings, then into pan to be drained before you can change the filter...
