Moly can be used at levels up to 1,000 ppm, safely. It's a very good multi-functional additive.
I have no idea if it's being used less now. I read before that moly will be used even more than it is now for GF-5, but that was from R.T Vanderbilt's site, which makes moly additives.
With there being many ways to make a good oil, it likely depends on the supplier and blender choice.
Quote:
It's well known in the industry that many sulfur containing compounds (not just MoDTC) can cause issues with "yellow metal" corrosion. MoDTC or similar compunds have been shown to cause this issue in poorly formulated lubricants, but it is fairly easy to "fix" the formulation with well known additives so the corrosion is not a problem even up to high treat rates of MoDTC (well over 1000ppm of Moly).
http://www.bobistheoilguy.com/forums/ubb...238#Post1336238
