dnewton3
Staff member
Is Delvac 1300 a high end group III? Probably not. But is it close by design and performance? Possibly so. The same has been mentioned about Rotella 10w-30 quite some time ago by Terry; I believe his comment was that the new forumation was "near synthetic". Just what does that mean? Is that in reference to the composition, or the performance? Well, we truly don't know. But, do we really have to?
JHZR2 made some good points, and here's another we should consider. I'm fairly confident in the information we all share, but it's fair to say that I do not know everything, so feel free to correct me.
PAO lubes are great in some circustances; they certainly flow and pump "better" than group II or III (to a lesser degree), and offer perhaps some small tangible evidence of less "resistance". However, everything I've researched about PAO and POE also show that they are not as capable in carrying the other desired additives that are necesary, in suspension. To aid in this endeavor, some portion of II or III is added to a IV or V to assist in the overall lubricant package.
Here's where JHZR2 hits the nail on the head. All lubes that are mass marketed (even boutique ones) are designed as a compromise between proffit margin, target marketability, and resources. No one I know of has any real use for a 100% "pure" PAO lube in daily operation of their vehicle. Some of the base stock advantages of a grp IV might make for less need of additives (for example VIIs), but on the other hand, you'll still need anti-agglomerates (dispersants) and detergents. Lower base group oils actually hold those in suspension better. So your Mobil 1, Amsoil, etc all have a bit of "other stuff" mixed in via some assitance from non-high-end products.
What makes each product different is the design intent of the fluid, the cost thresh-holds, etc. I doubt there is any 100% pure PAO that any of us use. Some are biased towards one end more than another. Face it; all lubricants are manipulated to varying degrees to meet the market needs. No one pumps pure crude from the ground and puts it straight into an engine. And since GTL and other high end synthetics do not exist in a "natural" state without being formulated by man, you can't say they are "pure" either, because they only become what we "blend" them to be!
I realize that it makes for interesting and lively debate, but in the end, it is the actual performance that matters most; not the composition. We should be most concerned with wear protection, contaminant control, and longevity. Then match up your operating environment to the lube that fits your individual situation.
"Best" only described one fluid choice for one particualar application. PAOs are not the "best" at everything, but they can be "better" choices over some alternatives, if you find your needs in certain ways.
However, "needs" are much different than "wants" ...
