It seems that alot of other 5W-40 and 0W-40 synthetics (and even 0W-30) have a higher VI. This seems a little low for such a supposedly fantastic, ester based 5W-40 wt. synthetic. Or is there more to the picture? Is its HTHS really>4.1?
From what I've gleaned from the last few days from of intensive searches and responses from these resident experts is that the VI of GC is 3.66 and the VI of M1 T&SUV is > 4.1quote:
Originally posted by LT4 Vette:
Do you know which oil has a higher HT/HS.....GC or T&SUV ??
How do you guys know the additive package is compatible and beneficial to an engine that needs an ACEA A3/B3/B4 spec for approval? Would M1 T&SUV, as the formula exists right now, be approved for modern Audi's, BMW's and MB's if they tried for that. Or if they just decided to label if differently and put it out as a euro spec oil? Is this stuff (T&SUV) the 5W-40 M1 syn on MB's approved list?quote:
Originally posted by Audi Junkie:
I think the low VI could be because of it's HD application, like a 15w-40 would be. Modest CC numbers too...probally it's tweaked for the hot end of the spectrum...HT/HS >4.1 a definate. That's why it's be fine for your car. No sludge, good cold flow and high HT/HS, that's all you need.
Thanks, Doug! So what is the Mobil SAE 5W-40 and 5W-40 Sint on Porsche's approved list?quote:
Originally posted by Doug Hillary:
Hi,
V8blitz - it is my understanding that Delvac 1 5w-40 (and M1 T&SUV 5w-40)would easily meet/exceed the ACEA specs you list. I asked this question of the Additive package suppliers and "the" people at EM many moons ago - that is why I use it
I am unsure if it is the MB Approved and Listed 5w-40 though. I suspect that it is and if you read the other thread you have started I may be about to find out!
Surely by now you will have "taken on board" that very few people on BITOG will criticise this product for use in most engines where the viscosity is suitable
It has an excellent track record over a great diversity of engine families and in every Country where it is sold. Simply, it is too expensive for some and for others an overkill
Regards
Doug
That's the HT/HS (High Temp / High Shear visc) not VI. All A3 calls for is HT/HS >3.5. To put D1/T&S in perspective, even a dino 15w-40 meets A3, Chevron Delo 400.quote:
No, I know the HTHS is>4.1. The VI is 151, however. That seems on the low side for an oil like this.quote:
Does this help explain why M1 0w40 (VI 187) sometimes becomes a 30 weight or is that a whole other matter all together?quote:
Originally posted by moribundman:
The lower the viscosity index , the less viscosity improvers (non-lubricating "plastic" additive) have been added. Less VI is better!
No, that helps. It's just that when reading a layman's guide to oil data it states that the higher the VI the better, as the higher the Flash the better, etc. So that was my confusion.quote:
There are many ways to achieve a high VI. One is to use an inherently high VI base oil. Another is to blend two base oils that together form a higher VI (like PAO and esters). You mentioned polymeric VI improvers. Mobil's SuperSyn is called a high viscosity index polyalphaolefin, and blending in a small quantity can allegedly replace or reduce the need for polymeric VI improver.quote:
True, but if you compare the viscosity index of two oils of the same viscosity range, the one with the higher viscosity index contains most likely more viscosity index improvers. That's more what I meant to say, but, admittedly, I was very unclear about it!quote:
That's not correct. The current Mobil 1 5W-30 is reputed to include no VI improvers. Its high VI is a result of the blending of PAO with alkylated napthalene, as well as SuperSyn (HVI PAO). It's known to be very shear stable as a result, and stays in viscosity very well. Mobil Clean 5000 contains VI improver. Here are their spec sheet entries:quote:
Okay, you are giving a specific example, while I was talking about "generally." Are you even comparing the same type oil? Isn't Drive Clean a mineral oil?quote:
Yes. That's simply because it's near impossible to make an oil that meets SAE 5W-50 without VI improver - even with high quality PAO/ester/AN base oils. These days, a "standard" motor oil is likely to contain Group II or Group III oil with a higher VI than previous generation Group I case oils. There are even multiple ways to make a 5W-30 - even among synthetic oils. Someone said it could be via a heavier oil with pour point depressants or a thinner oil with VI improver. Using VI improver is only one way to get the VI up. ExxonMobil sells its HVI PAO as an extremely shear stable means of increasing VI of conventional oils.quote:
The question is how the high viscosity index is achieved. Is it by using a high quality base oil, or by adding a lot of VIs? For example, due to its high VI index, Castrol Syntec 5W-50 is often maligned on this site, because it is said to be "loaded with VIs" in order to achieve its high spread.
