Don't do it. In the relatively short time I've been a member here, I've learned a lot. Although I haven't become a zealot convert, I'm a lot more comfortable with 5w-20 than I was two months ago, when used in an intended application. Of course, I'm still looking to see how the UOAs trend for older cars in coming years. Here's why you should stay away, IMO:
1) Your car doesn't call for it. I was desinged to maintain oil pressure and function well with thicker stuff. The oil makers are very aware of this and concerned to some degree, hence the warnings on most xw-20 bottles to use it only in intended applications.
2) Your engine in its presently worn state is likely to be even less tolerant of the thinner oil than it would have been when new.
3) Relative benefit: there are plenty of superb oils available to you, in an appropriate grade, that will interact well with your engine. The grass is NOT greener on the other side of this fence.
Use 0w-20 in this car ONLY IF your are willing to make yourself the subject of your own unscientific science experiment. Be careful, and good luck whatever you do.
[ May 18, 2004, 12:54 PM: Message edited by: ekpolk ]
