OVERKILL
$100 Site Donor 2021
Originally Posted By: Craig in Canada
Those referencing ambulances and other emergency response vehicles. I'd be pretty certain that specialized industrial engines like those in fire trucks are probably made to oil properly at idle, and probably have larger cooling systems meant to operate at idle. The same is probably true of any equipment that uses the main engine to drive hydraulic systems like bucket-lifts - the engineers know how they're going to be used and it's part of the design. I wouldn't even be surprised if police interceptors, or perhaps the entire model line they're based on, wouldn't have higher volume or higher speed oil pumps to deliver more oil volume/pressure at idle.
Ambulances (the Ford ones anyways) get the same engines as the Super Duty trucks.
The Crown Vic PI version has a factory oil cooler. Similar to those found on various Ford truck and SUV models. The oil pump is the same found in the rest of the Ford modular family.
