I have noticed these tend to crack around the engine mounting area, also where the wheels bolt in, and some where the handle brackets meet the deck. My question is this going to happen regardless simply as a result of age? I will need to post some pics when I get home but im not sure if i'd ever feel comfortable owning one. Even with a lifetime warranty they will cover the deck replacement part, and you as the "original" homeowner get stuck with the labor bill for your dealer to transfer the parts over to the new deck. While reading reviews online it seems they will deny the warranty if there is any evidence of impact damage. All used mowers will have this to some extent.
I also noticed that ever knook and cranny in your yard cause these mowers to also be jarring around as they lack the weight stay planted. Unless you roll your lawn frequently I would imagine this would beat up the deck and wheel mountings.
Opinions? I scored a bunch of used HRX217's with all kinds of problems ranging from blown engines to deck failures. Im going to build good ones with the parts from the broken ones.
