i read this on the interesting articles section:
motor oil myths and facts
Filter Change Interval
Back in the days of 3000 mile oil changes many manufacturers recommended filter changes only half as often because the filter did not become clogged with dirt at only 3000 miles. This was good advice back then, especially because with non-detergent motor oils a lot of the sludge remained stuck to internal engine parts rather than being carried in the oil to the filter. Nowadays the filter should be changed at every oil change. There are some people who believe so much in synthetic oil that they change filters without changing the oil. There's no harm in changing the filter without changing the oil, but there is no point in doing this.
so oil what i use is gm goodwrench sl/sj 10w30 oil,is it a detergent oil that helps clean the engine?i change it every 3000miles with new filter.my owners manual says to change it evey other oil change,but i changed evey oil change.
