A turbocharged 925CC engine with a 2.75 qt capacity sump? 95% of torque available in the usable range of 5,000 to 8,000 RPM
Manufacturer oil has two options 5w50 -35° F to 100° F and 10w50 0° F to 120° F (their branded oil is $15/qt) Oil change interval is 50hrs.
I along with 10 or so other friends have this same engine.. some use branded oil, some use T6 5w40, some use Mobil 15w50..
Normal driving would probably be considered racing conditions with the high rpm and high EGT temps of the turbo (800-1100F).
Is this oil up to the task? or do you have other suggestions?
