Hi guys, I know this is the go to forum for oil questions so here I am, any help is appreciated.
I have a 2000 Jeep Cherokee with 166,000 miles and I had a knocking sound at startup which goes away once it is warmed up (here is the sound with 5w30 Pennzoil Dino Oil):
https://www.youtube.com/watch?v=JhELwZgzXlY
I have gotten several theories from my favorite Jeep forum ranging from piston slap, rod knock, valve train, and flex plate. I figured the easiest thing to try first is an oil change so I did some reading and found that the high ZDDP content of Brad Penn oil should be good for my flat tappet cam 4.0. I decided to go with the 0w30 figuring that it would be good for cold winter in my area. So I purchased from Amazon Brad Penn 009-7126-12PK 0W-30 Partial Synthetic Racing Oil and put that in along with a premium Bosch oil filter and a day or two later the noise either went away or got a lot better (I don't know if it had to do with the oil or the outside temp, but I did not change anything else with the engine but the oil). Here is the sound (same early AM cold start) with the Brad Penn oil:
https://www.youtube.com/watch?v=4HwF11xApow
I guess my main question is will this oil be ok to use for 3,000 mile oil change intervals? I know it has the potential to foul the cat converter but I dont really care about swapping that out. I have read a lot about it but not sure what is current so I figured I would ask. Ideally I would like to run the Brad Penn 0w30 in the winter and the 10w40 in the summer since it seems to have helped with whatever my issue is. Is this a viable strategy? Thank you for any advice.
Also is there any good reason that oil would fix (or at least lessen) that knocking noise?
