Originally Posted By: onion
Yep, what he said.
Even after draining the block and radiator, you could still easily have a puddle in each. And if the thermostat is in good condition (sealing well), the top radiator hose won't drain.
I'm sure the 22qt spec if factor fill capacity. The amount that actually drains out will always be less.
And no, there are no other heat exchangers on that machine that use coolant.
When you say the top radiator hose will not drain, are you talking about a Bobcat 843? Or in general?
