I was telling the truthNew member, joined yesterday, and one of the first things is to disparage two brands with a silly comment. You figure it out.
I'd like to hear more about a bigger additive package adding to more wear at the beginning. If that were the case maybe Mobil 1 would be the best as it tends to have a weaker additive package than most others aside from supertech.
What exactly, are you trying to show?
PPM and...more is better? Without knowing what those additives actually are? Or how they perform? It’s a meaningless graph from an unknown source.
I could dump a couple of Tums in the oil, double the PPM calcium, and you would have a new “best” oil using the above criteria...because, you know, it has more PPM...
No that wouldn't work because then they wouldn't match the API SN or SN plus classification.What exactly, are you trying to show?
Reminds me of the MACT videos (VOA) where it’s a rolling PPM count … one had a PPM iron to its creditWhat exactly, are you trying to show?
Sorry brother, you lost me at Project FarmThe graph is from the project farm oil testing series. Via Blackstone labs testing
There is a reason why the API and OEMs have standardized tests. Not some guy in his garage with a one armed bandit testing machine making it up as he goes along.You're not a fan?
You miss the point.No that wouldn't work because then they wouldn't match the API SN or SN plus classification.
Project Farm doesn't know anything about what constitutes a valid test nor a valid analysis of oil quality. You don't evaluate oils they way they do and they display a fundamental lack of scientific knowledge about how it's actually done. And hint, Blackstone doesn't do it either. Not a criticism of what Blackstone does but that isn't their mission nor their competency.
It's worse than useless since people believe this stuff and make subsequent purchase decisions based on their worthless presentations.
Yep, nailed itNot much to add to that
