Is Amsoil ASL 5W-30 considered a "thick" 30 wt. oil?
Grand Forks, ND
I'm beginning to think Mobil 1 5W-30 is just too thin for me. Is Amsoil's full syn 5W-30 thicker than Mobil 1 at operating temp? Is the ASL close to a 40 weight? How does the Amsoil ASL compare to the German Castrol at operating temp?
What are the specs on Amsoil's ASL 5W-30?
Thank you for your help!
code:
AMSOIL 100% Synthetic 5W-30 Motor Oil (ASL)
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
11.7
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
63.4
Viscosity Index (ASTM D-2270)
182
CCS Viscosity @ -25°C, cP (ASTM D 2602)
2555
Borderline Pumping Temperature °C (°F) (ASTM D-3829)
Pour Point °C (°F) (ASTM D 97)
-51 (-60)
Flash Point °C (°F) (ASTM D 92)
230 (446)
Four Ball Wear Test (ASTM D-4172 B: 40 kg, 75°C, 1200 rpm, 1 hour, Scar in mm)
0.35
Noack Volatility, % weight loss (g/100g) (ASTM D-5800) 6.9
High Temperature/High Shear Viscosity cP, 150°C, 1.0 X 106 s.-1, (ASTM D 4683),
Minimum 3.5
Total Base Number
>11.0
It depends on what your operating temp is. If it is 212f the Mobil 1 will be thinner. But if it is 150f the Mobil 1 could actually be thicker at that temp. I would think that the Mobil 1 would be thinner at all temps though. I don't think you would be able to see it on your pressure gauge.
What Pablo said!
Mobil 1 is simply on the low side of a 30 weight viscosity but it is still "in grade."
I have found Amsoil ASL to be an excellent oil for the higher lattitudes, such as Iowa on north.
I use in my MIL's V-6 Oldsmobile all year round in Northeast Iowa.
Forkman,
She lives 5 miles north of Monticello, which is NE of Cedar Rapids, off Hgwy 38.
