Carlostrece
$100 Site Donor 2025
Can I know oil condition from a UOA if I didn't do a UOA earlier?
i.e. - Is a VOA a neccesity before beginning to do UOA?
You need a VOA base line to determine the general addpack signature and starting viscosity for comparison when the UOA results are returned.Can I know oil condition from a UOA if I didn't do a UOA earlier?
In my opinion, yes.i.e. - Is a VOA a neccesity before beginning to do UOA?
In this thread, VOAs of HPL's PPPCMO shows aluminum at 9-14ppm from two different labs. Without this knowledge and performing a UOA, you might think there's some wearing of aluminum parts going on. Having the baseline, you can start by subtracting the values from the VOA from the values in the UOA. Those would be the general numbers to track on subsequent UOAs for trend analysis.But if you want to track contamination and degradation, the VOA is paramount to knowing a baseline. It's especially important to know Si, oxidation, etc if you're going to use the UOA in an effort to stretch the OCIs.
I'm new to this forum (not the world) and testing of motor oils. Members here have caught errors on two of my UOA results, which the lab then corrected. Post the VOA and UOAs you receive and you'll get experienced eyes looking them over, catching potential anomalies.Also, look over the VOA and make sure things make sense ...
See this thread of mine with obvious erroneous values in the first report (compare first post info to the 13th post update).
The reality is that UOAs and VOAs are subject to error, so knowing the correct values is of the utmost importance.
OK. Thanks.I'm new to this forum (not the world) and testing of motor oils. Members here have caught errors on two of my UOA results, which the lab then corrected. Post the VOA and UOAs you receive and you'll get experienced eyes looking them over, catching potential anomalies.
I would say no because as Blackstone says, there isn't a statistically relevant difference in wear between brands of oil. Besides there are different tests for TBN depending on whether the oil is virgin or used so the numbers don't correlate.Can I know oil condition from a UOA if I didn't do a UOA earlier?
