Is a thin oil better for a short trip car?
toronto
hello my wife's 1992 Acura gets driven only 2miles a day to her office and back. The rest of this car's trips are all short. We're in toronto so the winter's get pretty brutal too. The question is, since the oil in this car rarely gets hot(or even warm in winter, probably) wouldn't I be better off with a 0W20 oil that is as thin as possible for better protection. I've got Mobil1 5W30 in it now and I'm doing 2X/year changes. spring and fall. mileage at each OCI is usually less than 5000miles. thanks.
I've always felt that a 0w20 would be the best oil for any car that is only driven very short distances and rarely gets up to full operating temperature.
I think you are on the right track. Start-up wear is probably this vehicle's greatest enemy so 0w20 or 0w30 would be good choices. I would try to run it for 20 to 30 minutes on occasion to cook off any moisture forming in the oil.
quote:
Originally posted by mikemc: I think you are on the right track. Start-up wear is probably this vehicle's greatest enemy so 0w20 or 0w30 would be good choices. I would try to run it for 20 to 30 minutes on occasion to cook off any moisture forming in the oil.
does that actually help. I know you can get rid of some of the condensation but the fuel dilution and the acid's aren't really going anywhere. sad part is 1 month of my wife driving the car=me taking it on the highway for 45minutes. same distance covered.
quote:
Originally posted by Patman: I've always felt that a 0w20 would be the best oil for any car that is only driven very short distances and rarely gets up to full operating temperature.
[Cheers!]
The additive package of the oil should be considered along with viscosity. If the short trips bring down the TBN too far, then the engine is being damaged. Frequent oil changes may be helpful.
quote:
That is why you change the oil at least once a year on a low mileage vehicle, to remove acids, soot, etc.
Fuel is more volatile than water. It will evaporate first.
Have you seen/smelled old gas? What does fuel do when it sits? The volatiles do go away, and what is left eventually turns to varnish. Accumulation over a long period of time will leave the oil really nasty. I would use at least a 5W-30 and change every 3 months. I probably would not waste my money with full synthetic unless needed for the climate.
this is interesting. from Redline, about their 5W20 "The lightest multigrade street engine oil that we sell. Excellent performance in weather where cold starting and short running duration are concerns."
