From the owner's manual for 1977 Ford Truck, F-100 thru F350, and P-Series:
I wonder how much zddp was in the SE/CC oil. Wouldn't think the next step in oils (CD over CC) would have been presenting too low of a zddp issue. I thought we had just gotten to that point today with SM oil.
Quote:
Use only those oils that meet Ford Specification …. Or API Classification SE or SE/CC.
NOTE—Oils of the above classifications which also meet API Classification CD are not recommended unless: the oil supplier indicates they contain a minimum of 0.10 weight percent phosphorus as zinc dialkyldithiophosphate (alkyl zinc) or a high quality fully formulated zinc dialkyldithiophosphate oil conditioner such as Ford Part Number D2AZ-19579-A is added at each oil change in a quantity sufficient to provide a minimum of 0.10 weight percent phosphorus as zinc dialkyldithiophosphate (16 ounces of conditioner to 5 quarts of oil.
