Ken, there is a complex formula concerning the clearance between the journal and bearings.
Here is a nice article from Molakule that touches it.
Article
Quoting Molakule
![[bowdown]](/forums/graemlins/bowdown.gif)
"Bearing friction is determined by an empirical equation (derived by test data) called the “McKee” equation as: Eqn. 1, f = 1x10^-10[473(ZN/p)D/C] + k, where k is a constant determined from another equation or chart for various L/D ratios; L is length of bearing (in.), D is diameter of bearing (in.), N is speed of journal in rpm, N’ is speed of journal in rps, Z is absolute viscosity in cP, C is diametral clearance between bearing and journal in inches. For most bearings in automotive use, k = 0.002. p is pressure = W/LD, W is bearing load in lbs. An average value for D/C is 1000. In automobile and piston aircraft engines, the loads W, are: Main – 700-1700 lbs., Crankpin – 1,400-3,400 lbs., and Wrist pin - 2,000-5,000 lbs. The ratio of e to the radial clearance is called the “attitude” and is defined as: Eqn. 2, A = 2e/C = 1- 2Ho/C. Ho is the “Minimum Film Thickness.” So how does one find the viscosity required for a bearing? One uses the “McKee” equation, along with the “Lasche” equation, for bearing heat generation and dissipation, Hd and Hg, and equates these equations to find the viscosity required!"
