If it were mine I would treat it like one of the infamous Toyota Camry "Sludge Monster" engines as it has many of the same problems.quote:
Originally posted by farrarfan1:
Just purchased my wife a 2004 Chrysler Concorde with the 2.7l dohc 24 valve engine. Instinct tells me this engine will be hard on oil so I went to google for research on Wal Mart Super Tech synthetic and ended up here.She only drives the car 6-7000 miles ayear so it falls under the 3month/ 3,000 mile oil change for warranty, thought I'd try synthetic. Anyway when I found this message I thought I'd throw in 2 cents worth. I'm a 25 year veteran of the Indiana State Police and am currently driving a 2001 CVPI that was issued to me in July 2001. Our commissions ( ISP word for patrol car) currently has 106,000 miles on it. New 2004 CVPI sitting at the garage in Indy waiting for final equiptment check before it's issued to me. Our cars are issued to us individually so one officer is the only one to drive the car and we can use them for personal off duty use. Oil changes are done at 5,000 miles using re-refined 5w30 oil and either Motorcraft oe Wix filters depending on which supplier has the bid.My car runs as good as the day I got it, and only uses 1/2 quart of oil between changes and this is always after the 4,000 mark. Probably the additives are going. We have very few engine failures that are caused by a lubricated part breaking. Most cars go well past 100,000 miles and are still running good. This is on a re-refined oil that is not the weight Ford recomends and it is also a longer drain interval than is recomended.Something to think about in the debate I've seen on here about the 5w20 oil Ford recomends. Previous POV that I traded on the Concorde was a Grand Marquis with 19,000 miles, all on Motorcraft 5W20. Not many miles but the car ran well on it. Any advice on oil for the 2.7l would be appreciated.
If you are going to dump the oil every 3 month 1500-2000 mi I would just use the cheapest SL rated Dino I could find and a SuperTech Filter.
I would change it every 6 months and not go over 4000 mi.
Havoline/Chevron 10W-30 ($1.10) for the warmest 6 months and 5W-30 ($1.02) for the coldest
Year round
Motorcraft 5W-30 ($1.42). Although it is not advertised as such it is now a Group II/III Hydrocracked/Synthetic Blend according to the back label. At this time the 10W-30 is still just Hydrocracked Group II.
A full synthetic is a waste of money for 6 month 3000-4000 mi drains. If you insist you can buy Mobil 1 10W-30 or 5W-30 ($19.77-5 QT)
If you are going to have WalMart do the oil change I would go with the 5W-30 Motorcraft as they are going to just charge you the $2.00 upcharge for bottled oil (Since it isnt marketed as a blend) and upgrade to the the SuperTech Filter (Champion built) $0.85 upcharge as most of the members of this site prefer it to the standard Fram.
If you are doing a self-change I would use a OEM Mopar filter until you can match it up with the supplier.
Gene
