Intake Plastic Plenum Torque Specs and Tightening Sequence
Florida
98 Expedition 5.4 4x4
Does anyone have the tightening sequence and torques specs for the ALUMINUM intake manifold to the heads and the PLASTIC plenum to aluminum intake?
I saw plenty of resources online with the information, but not much that defines the specs specific for the plastic and aluminum components
Hope it helps.
Yep, that's the one I have been seeing. Is that for the aluminum intake to head and plastic plenum to intake?
You may want to re-torque the plastic plenum after a few hundred miles, if it's the silicone rubber gasket type it can settle and become loose.
Interesting you would bring that up.
I had new gaskets installed when the motor was installed, but since I have the intake removed (I won't be removing it again, unless there is a problem), I figured I would just replace the intake gaskets while I have easy access. So my options are to replace the plenum gasket with a new one, or just re-torque the one that was installed a couple years ago and hope the gasket that was installed holds up.
What is the function of that plenum anyways?
Never reuse a gasket here. New always. Plenum is an extension of the intake manifold - 2 pieces rather than one for weight and cost saving.
That and trying to cast it in one piece might have been beyond the capabilities at the time.
