I think it's important to remember the most likely "why" for saying the .1% zinc: antiwear. There are lots of trace minerals that do well, such as moly. I wouldn't be too concerned with 1977 specs vs. today.
As I recall, the 345 is a low compression, low stress, eternal life truck engine. People can get concerned about flat tappets but unless you've got a cam or high-pressure valve springs, it's a non-issue.
Pennzoil traditionally has a lot of moly in it, and I suspect their HM does as well. I haven't tried ST. Mobil1 is pretty thin and may not give you the results.
Then again it may be front and rear seal time after 25 years
What kind of miles are on it?
