I think Castrol refreshing labels forced the market to change upMarketing 101!
Actually using start stop usually reduces oil dilution due to less idle time…To me start-stop means higher fuel dilution.
Fuel dilution is countered by more viscosity.
I bet it's a 20 weight that's on the very edge of being a 20 weight spec which I think is like 9.7cSt at 100c.
Start stop engines seem to have the worst fuel dilution. That start stop function starts with a blast of fuel, stopping allows the piston tops and cylinder bores to cool off, overall makes hitting operating temperature take longer, may not be able hit operating temperature on shorter trips at all. Direct injection makes it even worse.Actually using start stop usually reduces oil dilution due to less idle time…
Not unless it's cheaper and easier to get than PP and available in 5w-30.Is anyone gonna buy a quart and do VOA?
Exactly! For oil burner I’d use filtered used oil or some 15w40; but I have a stashNot unless it's cheaper and easier to get than PP and available in 5w-30.
I utilize start/stop on my DI engine and my report showed <1% fuel dilution after about 4,000 milesStart stop engines seem to have the worst fuel dilution. That start stop function starts with a blast of fuel, stopping allows the piston tops and cylinder bores to cool off, overall makes hitting operating temperature take longer, may not be able hit operating temperature on shorter trips at all. Direct injection makes it even worse.
Yeah I used to think stop start or having a hybrid would make oil last longer. Nope.
During winter I constantly run our at in sport mode where it doesn't start/stop most of the time.
A lot of us with DI stop start engines are having to change oil because of fuel dilution. If I can take the car on a nice little road trip at 75mph for about an hour each way that will cook nearly all of the fuel out of the oil. You have low fuel dilution not because of DI with auto start/stop design, it's some other factor like ideal amounts of highway driving, warm climate, ect.I utilize start/stop on my DI engine and my report showed <1% fuel dilution after about 4,000 miles
