Infiniti FX 35 2004 type of coolant
It should be what Infiniti/Nissan calls their green concentrate, not to be confused with conventional green. Blue would apparently work after a flush. As for the second part, unfortunately, I don't know of one.
Valvoline Zerex Asian available at Walmart. I use the red because the blue wasn't available when I switched over, but either color works fine, just flush out the old first.
Originally Posted by Warstud
Pentofrost A2 >>>>> https://www.autozone.com/antifreeze...ntifreeze-engine-coolant/534412_580165_0
If you can find this at AZ for the listed price ($10), a good choice for topic vehicle. It would be a match to 04 Nissan green AF. Also, for a simple radiator d&f, equivalent long service interval AF premixes which match current Nissan blue LL AF would work. That would be Zerex Asian Formula, WM Zerex/Valv Asian and Pentofrost A3. Those are backward compatible with old Nissan Green, no flush needed. However Pentofrost A2 especially if available at AZ store for that price, a good choice.
