Here is my summary for the upcoming ACEA 2020 sequences from the presentation.
None of the legacy categories will have the three modern-engine tests: LSPI, chain wear, and turbocharger deposits. There are only two new categories for light-duty engines: A7/B7 and C6, which will have all three aforementioned modern-engine tests included.
It also looks like thick oils (HTHS ⥠3.5 cP) are beginning to be phased out in Europe as well, as their categories are not being replaced with newer categories and are becoming legacy categories as a result.
- A3/B3 will be removed
- A3/B4 will remain as a legacy category
- A5/B5 will be removed
- A7/B7 will be introduced (SAE xW-30 oils with HTHS ⤠3.5 cP, same performance spec as the new C6, LSPI, chain wear and turbocharger deposits included)
- C1 will be removed
- C2 will remain as a legacy category
- C3 will remain as a legacy category
- C4 will remain as a legacy category
- C5 will remain as a legacy category, being phased out to be replaced with C6)
- C6 will be introduced (SAE xW-20 oils, same performance spec as the new A7/B7, LSPI, chain wear and turbocharger deposits included)
- SAE 0W-12 and SAE 0W-16 oils postponed to next ACEA update
- E4 will remain for legacy engines
- E6 will be removed
- E7 will remain for legacy engines
- E8 will be introduced (in line with API CK-4)
- E9 will be removed
- E11 will be introduced (in line with API CK-4)
