I have a beater 1989 prelude that at one point in it's life had a very competant Jiffy Lube employee strip the oil drain plug threads. I'm too lazy to pull the oil pan and drill and tap new threads, so I just buy those rubber plugs and reuse them until they don't look like they will hold together very well (usually 2-3 times). But oil changes are boring anyway, so I'd say lets try something different.
My plan is to use Mobil 1 SUV oil and go for one year. I will obviously have to top up and I will do an occasional filter change. I will keep "detailed" records of milage and the amount of oil added in addition to getting an oil analysis done at the end of the year.
I have done the Auto RX back in the spring and have been running Delvac 1300 since. Upper end looked spotless when I took off the valve cover to adjust valve lash. Driving is either long highway miles back and forth to school or short jaunts in the city while I am home. I expect the milage to be around 10k when done.
