1.) I'd replace the PCV Valve with an OEM part.
2.) Pull the plugs and drop a shot glass of Break-Free in each cylinder, reinstall the plugs. Let it sit at least overnight. Over two nights better.
Break-Free is a carbon gun solvent for loosening and removing stubborn carbon fouling in barrels (shooters version of coking). It will soak into the ring pack and loosen what it can ...
3.) Fire it up and drive around the block - change oil to Rotella T6 5W-40 and add a full can of Kreen. Do this on every oil change, for at least three. When the oil turns really dark, change it, no matter the mileage.
The oil going past the rings is turning to ash in the CAT. Soon it will completely block the CAT (ash cap) and you'll have to take it off and either clean it, or gut it. I'd clean it with compressed air from the back forward and use a brush in the front. Set it aside to remount when you need to get smogged. Run a straight pipe section between smog checks.
It'll still be an economical car to commute. Prolly cut the oil consumption in 1/2. But, you'll never completely cure it.
If it was my car, it'd get a Break-Free ring soak every oil change and full can of Kreen from here on out ...
