Gokhan
What is hydrodynamic lubrication ? If I set a crankshaft down into its main bearing journals and bolt the main caps on and give the crankshaft a spin by hand, is that hydrodynamic lubrication?
It's the same thing as hydroplaning of a car on water. There are three lubrication variables: viscosity , speed (v), and load pressure (P). When the load pressure (weight of the car divided by the total contact area of the tires or the load pressure on the crankshaft/connecting rod/piston) is small enough, and/or the speed (speed of the car or RPM of the engine) is high enough, and/or the viscosity (of the oil or water) is high enough, your tires lose contact with the road or there is no metal-to-metal contact in the bearing/piston/whatever is lubricated.
