I Ohm'd my son's stock electric fuel pump from his import car. It read 0.00. I applied power and it seemed like it was working steady but weak. Do the Zeroes mean it's bad or on it's way out?
Did it have a good ground?I Ohm'd my son's stock electric fuel pump from his import car. It read 0.00. I applied power and it seemed like it was working steady but weak. Do the Zeroes mean it's bad or on it's way out?
1-2 Ohms would be considered normal. But it's obviously not shorted like your resistance test would lead you to believe either. I'd likely question your meters accuracy.
Measuring resistance is prevalent in automotive diagnostic literature, But.....With few exceptions.....I find it to be just about useless. Amperage ramps & signatures via a scope paint a much clearer picture (For me anyway)
YesDid it have a good ground?
I used an Amprobe ACDC 3000 meter1-2 Ohms would be considered normal. But it's obviously not shorted like your resistance test would lead you to believe either. I'd likely question your meters accuracy.
Do you have a pic of your 66 Nova? I'm a 60's early 70's muscle car freak!
IIRC...anything pre-72(?) is emissions exempt. (please correct me if I'm wrong)I did not think anything that old would be allowed on the road in CA with all the low pollution standards there.
