JHZR2
Staff member
Trying to brainstorm to help a friend who lives very close to water, in an area where his garage floor is a few feet below the base flood elevation.
What this means/what he is looking to do is have as small and cheap a setup as possible to temporarily lift a vehicle 3-4’ up, in case of storm surge/flooding.
It is imperative to note that it is not intended to work on the car or be under the car. This is a fast storm prep get the car up due to potential storm surge type situation. Get it up, and then get it down and back in use as fast as possible.
Friend is not a car guy, thus some sort of $2k hydraulic lift isn’t in the cards. It’s also a single car garage, fwiw, so space is at a premium. I was thinking a kwik lift like mine, which can be driven on, and gets something like 20” of floor raised, so the bottom of the car is farther above that. But it’s a heavy and expensive piece of steel, not really suited for a temporary thing.
Im thinking wood cribbing is the best bet, but how to apply that high? How to lift the car efficiently and evenly. I don’t thing four bottle or scissor jacks would be out of the question, but for large hydraulic trolley jacks probably are.
im thinking low wood ramps that can easily be driven on, raise the car with scissor jacks (spun with a power tool), and then insert cribbing as the vehicle is lifted.
I think the key to efficiency is to lift under the tire, as jacking is very inefficient if the suspension loads and unloads.
ideally I think woukd be no hydraulics. I wish there was a good way with four hi-lift jacks... then the suspension hanging might not matter as much. Put 2x4s under the jack points and lift up somehow with the high lift, a click or two at a time. then lower into blocks.
Anyway, ideas? Key is to quickly and easily get it up for a few hours, then back down. Nothing more capable than that.
Thanks!
Thanks!
