I want to run a thicker oil but…
I bought a truck with 250k to use as a farm truck. It doesn’t leak oil and it doesn’t smoke but it’s using a quart of oil every 500 or so miles. I’m considering running a thicker oil to see if it slows consumption but I’ve seen so many oil experts online that say to not go heavier than the manufacturer recommended viscosity. It’s a 2004 F150 5.4L and the factory recommends 5w20. Twenty weight isn’t very thick. Would it be unspeakable to use good old 10w30?
A handful of gurus on YouTube advise not to go thinner than the low number and not to go thicker than the high number of the factory oil. I just watched a video from TheMotorOilGeek that said as much.
I’m located in the Mississippi delta. Low temps rarely make it below the teens and thats only a few days a year. Summer has 30 days of 90-100 degree days. The truck is driven about 50 miles a week with 3 or 4 250 mile round trips per year. Most trips are around 20 minutes long.
Should I be thinking thicker oil or just adding a quart of Lucas?
The engine is shot. Put some thick thick stuff in there and hope for the best. I highly doubt it's going to make things worse.
Lucas! No!
I'd go with a 5w30, and see how it does, then you can go to a 10w 30 or a 5w40.
The first number is the cold temperature pumpability. In Mississippi that number is virtually irrelevant to you. 0W, 5W-, 10W - doesn't matter in your case if your never below 0F.
The second number is the viscosity. Yours specs a 20 weight it seems. I would go up to xxw-30 and start there and see if the oil consumption goes down. What brand is mostly irrelevant. If your only going 50 miles a week then its going to take a while to figure out what helps.
If you wanted to try to improve things you could read through the Valvoline restore and protect threads and see if that might be an option for you.
If it’s drinking a quart every 500 miles, you will be fine with SuperTech 10W-30. It’s not worth the cost of anything else.
Heavier oil will not hurt your engine.
I have an email from Lake how to find which oil works best for my application. After several recommended steps with testing, he recommended moving up a grade. Moving up is not going to create any new problems.
Find a good-quality oil, like the Valvoline Restore & Protect or Mobil 1 mentioned earlier in a 5W-30 and use it without any additional oil additive. WalMart currently has some good oil sales happening. Consider moving up to a 5W-40, also.
