Originally Posted By: HTSS_TR
The engineers who design/test the GTI for what usage ? They tested it in Germany on Autobahn where they can redline the engine for many miles. Where in US you can redline the GTI more than a minute ?
Rubbish. Not every road in Germany is an autobahn. And it's not only Germany that VW cars are made for. The cars are designed to drive in all circumstances, from stuck in city traffic, to 180km/h+ on the autobahn, from -35 Celsius and below in the arctic, to 40 Celsius and above in the desert. The oil spec is designed to perform in ALL the above circumstances. And it's designed for the particular way that VW design their engines.
If you really want to go outside VW approved oils, at least choose an oil with similar spec such as Mercedes Benz. But going outside spec, you're playing Russian Roulette, and knowing VW, I'd say you will be shortening the life of your engine considerably.
You won't gain any real advantage, so just buy the correct oil (or a higher-specced VW oil that is backwards compatible).
