I am looking for replacement tires for my Fusion. While expensive, I've decided on Michelin Primacy MXM4 tires in my stock 235 /45 R18 size. However, there are two choices for the same tire with a few small variations. While I am aware that some OE tires have unique compounds, for the specific vehicle vs the same tire for general vehicles, this doesn't seem to be the case. The difference is pressure, width, and tread depth. Below are the specs differences between the two. Can someone explain these differences (other than the obvious). How should this affect which set I should get?
Since tires are probably one of the most important items you can put on your car, I want to make sure I get the best fit.
1. 235/45R18 94V
Maximum Inflation Pressure: 51 PSI
Tread Depth:9.5/32"
Tread Width: 8.5"
2. 235/45R18 94V
Maximum Inflation Pressure: 44 PSI
Tread Depth:8.5/32"
Tread Width: 7.9"
1. 235/45R18 94V
Tread Depth:9.5/32"
Tread Width: 8.5"
2. 235/45R18 94V
Tread Depth:8.5/32"
Tread Width: 7.9"
